install injectors chore.
In the middle of the job, need a break. Have had to go buy" T handle 40mm Torx (actually the set) cause its the only thing around here that will fit in the small spaces. While I was at it, bought 2 10mm wrenches cause I cant find mine. Bought some Aluminum "wheel" cleaner to help clean things up. The fun part is taking the runners completely off to change to Eldebrock hi flow runners. What a pain in the butt.Putting it back together now and can hear the big boys running at the U.S.Nationals up the road a bit. Now, if I just remember where all the long bolts go versus the short ones.
Cruise-In II Veteran
Careful when you install the 9th injector & its line....
