New ring gear onto carrier is loose
St. Jude Donor '13
I have a new Richmond ring gear going into a dana 36 carrier. The gear slips on and off easily with little effort.
Everywhere I read it says to draw the gear on via the bolts or heat the ring gear.
The gear moves on the carrier flange about 0.002" radially before torquing bolts.
Can anyone comment on their experience with this?
Any feedback is appreciated.
St. Jude Donor '13
Called Richmond, they said the gear ID is in spec and eye carrier is too small. Not sure how that happens?
The stock gear had to be tapped off.
Anyone able to measure a gear they may have off the car? Anyone able to measure the case od?
The ring gear ID appears to be 4.777.
Richmond really couldn't offer anything else after they said their gear is in spec?
2021 C4 of the Year - Modified Finalist
I have a dana 36 out in my garage with the gear off the carrier, I will go and measure it later when I have time. The ring and pinion are richmond when I took it apart the ring fell right off.
If the Richmond parts have the correct part #'s etched on them to match the gear set and the bolts start to the ring gear you've got correct parts. What are the number off of the GM gears you removed from the carrier?
St. Jude Donor '13
Eutu, thanks. That is the stock Dana gear measuring 4.774
I'm not advocating using bolts to draw the gear on or any other practice at this time. However a large portion internet content suggests so. Regardless of that practice's validity, it demonstrates a rather tighter fit is usually present.
Your choices for gear kits for the D36 are very limited. Perhaps you should check the other for the ID of theirs and make a decision based on, "what's out there". The other thing to consider is because of the "thick ring gear" and the mass of the material maybe the ID is an accommodation required.
euti1984 has a carrier casting that I couldn't actually pinpoint the production range but maybe yours will. What is the casting number on the carrier that you have presently?
