Steering Issue
Cruising
Steering Issue
My 1985 Vette has 75K miles on it and I'm noticing a quarter to one half inch play in the steering wheel when sitting still or moving. Do those of you who have C4 Vettes in the range of 1984 to 1986 have this sort of movement? I suspect that my rack and pinion unit may be showing signs of wear or perhaps rod end play although my mechanic says not. Any suggestions?
Thanks,
Bill
Thanks,
Bill
I would look into the intermediate shaft if the mechanic says that the rack is OK. I would have thought if he was asked to check he might have checked that also and he would have also checked maybe the rack mounting bushings. You might ask that he does this OR maybe with your hands on the intermediate shaft have someone in the car shake the steering wheel. You should feel intermediate shaft problems.
Cruising
http://www.ebay.com/itm/1984-1985-C4-CORVETTE-ADJUSTABLE-STEERING-GEAR-COUPLING-SHAFT-7843500-/261541521493?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce516e855&vxp=mtr
There are many threads discussing the repair of, just by using the search. There are less expensive eBay offerings also but you're getting maybe what you've already GOT!
Here's a thread that comes to mind for consideration:
https://www.corvetteforum.com/forums...ing-shaft.html
EDIT: I forgot that Corvette Central actually offers the '84 - '85 in a "reconditioned" assembly. It's an option maybe:
Use the OE/GM part # 7843500 or their part # 564214 to search
http://www.corvettecentral.com/
