TPI procharger on LT-1?
what would I need to do to get a Procharger P600B to work with my LT-1, will the FMU work?, bracketry, ducts? Anyone know the diff between the LT-1 version and the TPI version?
Jay :blueangel:
Jay :blueangel:
Re: TPI procharger on LT-1? (phartknocker)
I'm pretty sure the head unit is the same, however, the bracketry, FMU, and/or fuel pump might be different. Give ATI a call and ask them. Just a simple comparison of part numbers should answer your question.
If you're asking because you can get the head unit used, I'm not sure if ATI sells the bracketry separate. I would think they would.
http://www.procharger.com/contact.html
Re: TPI procharger on LT-1? (vvv90)
The P600B is just the type of compressor that comes with the kit. I know that the LT-1 kits already come with a P600B compressor. If you give me the year and engine type the P6000B came off of and what year your trying to put it on I might can see what needs to be done.
ATI will sell seperately
I purchased all the brackets, nuts, bolts, spacers, oil feed / return lines, idler, and even a smaller pulley for under $500. Just call ATI and get with a Tech. Tell him the pieces you have, and he will list the parts out for you. They were very helpful with mine.
Re: TPI procharger on LT-1? (ForceInjection)
called ATI, they seemed more interested in selling me a new system, but eventually got a quote of around 2200.00 for the dual intercoolers, parts bag, fmu, pump, brackets, etc, the guy didn't even realize that the 93 wasn't a MAF car, kind of dissapointing. :U
