Pro Flo XT Intake with DIY adaptor for TPI Throttle body
Old 10-17-2014, 11:01 AM
dave_85
dave_85's Avatar
Default Pro Flo XT Intake with DIY adaptor for TPI Throttle body
Here is another way to install the Pro Flo XT on a 350 C4 Vette. I made an adaptor so I could use my TPI TB and cables. I also reused my Holley SP fuel rails and regulator. You need a small HEI distributor and remote coil. I used a TPIS Mini ram water neck. With this setup, hood clearance is no problem, about a ½ inch at the TB. (See the photo with the yellow clay on top of the TB). I made the adapter with a 2in hole saw and a drill press. I cut off the upper tab for the LS TB with a circular saw and a plywood jig bolted to the manifold to cut straight. I drilled and tapped the side of the intake to mount a Holley throttle cable bracket to the driver’s side of the intake. I made a plastic wedge to get it to line up with the TB. I haven’t had it dynoed but my SOTPs meter feels good.
cardo0 (11-27-2019)
Old 10-17-2014, 01:07 PM
Silver96ce
Silver96ce's Avatar
Fantastic job and nice work!
Old 10-17-2014, 02:05 PM
JackDidley
JackDidley's Avatar
Nice. 10 years ago guys would have stood in line all day to get that set up. Including me. Not that many guys modding l98s now. Anyway, looks damn good.
Old 10-17-2014, 04:48 PM
eutu1984
eutu1984's Avatar
2021 C4 of the Year - Modified Finalist
Old 10-17-2014, 05:35 PM
tpi 421 vette
tpi 421 vette's Avatar
Nice Job! I would like to hear more results using that intake.
Old 10-17-2014, 09:57 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Curious also. Looks like an improved LT1 type intake.
Old 10-18-2014, 04:45 AM
blackozvet
blackozvet's Avatar
isnt it fun making stuff out of alloy !
Old 10-18-2014, 09:46 AM
SeanHM
SeanHM's Avatar
Oh that's sexy! Can't wait to hear the results. I have been thinking more about utilizing a traditional small block versus going LS when I get around to getting my car. I always loved the look of the tpi motors.
Old 10-18-2014, 04:48 PM
jagriffinsf
jagriffinsf's Avatar
Default Excellent!
Very nice work! The more I look into the costs/time associated with swapping a LS and hooking it to my ZF, the more I want to go with a Pro Flo in the future and call it a day.
Old 10-18-2014, 08:32 PM
dave_85
dave_85's Avatar
Yes. I cut the 3/4in plate with my chop saw and it's not too expensive.
If you make a mistake just fill it in with JB weld.
Old 10-20-2014, 03:00 PM
ch@0s
ch@0s's Avatar
GJ dave
Old 10-20-2014, 10:23 PM
blackozvet
blackozvet's Avatar
I had to buy a piece of 10mm thick plate to make the TB adaptor, and made a themostat housing blank plate with the leftover, then had to go to a friends workshop to find a scrap piece to make the throttle bracket plate, I was cleaning out the back of the garage last week and found a 4 metre long (13 feet) by 10mm thick piece of alloy amongst the scrap steel !
Old 04-30-2015, 08:59 PM
jagriffinsf
Any updates on your car? How is it driving? Dyno or track numbers? Would you do it over again or would you suggest something else?
Thanks!
Old 11-23-2019, 08:42 PM
Dustin James
Dustin James's Avatar
Thanks!
Interested as well - I'm about to drop in a 383 stroker with a Pro Flo 4 XT style and have lots of questions! haha
Old 11-23-2019, 09:06 PM
Dustin James
Here's my setup! I'm wondering if an L88 hood will have enough clearance! hmmmmm. Thoughts?
Old 11-26-2019, 07:18 AM
Kubs
Kubs's Avatar
Received 1,722 Likes on 931 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Very Creative! Nice work!
Old 06-15-2021, 11:35 AM
89fast5oh
4th Gear
89fast5oh's Avatar
I know this is a very old thread but I am hoping Dave_85 will see this.
I want to do this exact same modification but want to know how he went about centering the adapter plate on the Pro Flo XT manifold so when he drilled/ground out for the dual throttle blades so it was centered.
AZSP33D (06-15-2021)
To Pro Flo XT Intake with DIY adaptor for TPI Throttle body
Old 06-15-2021, 02:28 PM
kanvasman
kanvasman's Avatar
See if you can PM him.
Old 06-18-2021, 02:11 PM
89fast5oh
4th Gear
89fast5oh's Avatar
I've been in touch with him through the email option.
Old 11-26-2021, 07:00 PM
TorchLT4
TorchLT4's Avatar
Default New info?
What did you find out, any updates?
Quick Reply: Pro Flo XT Intake with DIY adaptor for TPI Throttle body
