4+3 Overdrive Freewheeling,will not engage
1986 C4, Doug Nash 4+3.
Overdrive will not engage. New relay, new switch on shifter ****. The fluid and filter have been freshly changed. The OD light comes on at the correct time and the OD switch works like it should.
The overdrive is doing something... I'm just not sure what. When the light comes on the OD will not shift. Here's the strange part, when the OD light is on and I'm driving down hill the car seems to coast like it is in neutral. It will continue to coast until the car slows to the point where the engine RPM matches the wheel speed for the particular gear that I'm in, at which point it continues to drive normally with NO overdrive, regardless of whether the OD light is on or off.
Looking forward to hearing some ideas from the experts!
-Matt
-Matt
Inside the OD unit is a solenoid that engages it. If it were mine, I'd pull the pan and visually inspect, remove, and test it. Also check for lots of metal particles on the magnet. You might get lucky or it might be time for a rebuild.
They run hot have a short fluid life. If it wasn't changed for a long time or it ran low, it will fail prematurely. Most oil change places only checked the trans fill (if that).
This page from the SM might help: https://secure.flickr.com/photos/jvienneau/15374691087/
-Matt
-Matt
SK has all the parts and great info call them
http://www.skspeed.com/manual-transmission-shop.aspx
What is the best way to test the solenoid? It looked ok visually. The fluid looked good as well.
Does anyone know how much resistance the coil in the solonoid should have? Mine seems high.
Matt
I feel your pain..
I pulled the pan and changed the fluid/filter myself. Everything looked good.
Matt
Matt
The OD relay is located near the wiper motor behind the fuel pump relay. However, if you get the OD light on your panel your relay is working. Im thinking our OD friction plates are worn out. I'm going to test by getting the wheels off the ground and seeing if the OD will engage without being under load.
Matt
Matt
I hope its not the pressure plates...i would be very depressed. Bought a nee relay today and am hoping it may do something. Mine was working fine and you knew when it switch in our out of OD as the was a thunk you could hear even with the clutch in. Then it started to take longer to kick in until one day it just stopped....it feels like it has the kcik down feature enabled...just put a new TPS sensor in as well.
http://www.corvetteactioncenter.com/...-unit-610.html
This will get you started, my recommendation is a factory manual. The piece below is written by David Fulcher in Atlanta, he is an expert on the 4/3. Your biggest problem is going to be hard parts availability. I have done 2 of them, they are not difficult but you need to be aware of some key points, so following the book is a requirement.
http://api.viglink.com/api/click?for...sion-shop.aspx
For the people who have rebuilt the overdrive before...
Will I need any special tools for this project? I'm slowly mustering up the resolve to tackle this on my own.
-Matt
-Matt
You don't really need anything special. There are three 1/8 pipe plugs in the rear of the OD unit, have a good allen wrench socket to remove these. Some have been very tight and once they are buggered up they are a pain to remove. You will need three metric cap screws about an 1 1/2 long (I cant remember the exact size) these are used to hold the direct drive piston under slight compression. You can then remove every thing very easily. As far as all the info on bearing pre load and the measuring tools, my experience is the cases are so rough it's hard to get an accurate reading. Read what I sent you, if I can add any thing I will.
I Have to say that I have the exact some problem as Scott0757. I've changed the fluid and did not see any surprises in the waste. I know that it switches in/out of overdrive by the drop in rpm and the clunk when switching the OD button.
If I keep constant pressure on the gas on level highway while in OD, the car will slow down like its coasting. As soon as I apply any gas at all, it switches out of OD and starts to easily pickup speed.
Can this just be a TPS issue?
I'd like to believe a slipping clutch pack would cause the rpms to ramp up dramatically more than just the difference between normal and OD (like 2900 RPM at 65, VS 2000 RPM in OD) but it doesn't seem to shoot up above the normal RPM for being out of OD.
Thanks for the help!
