Location of O2 Sensor
Where is the left rear O2sensor located on the exhaust on a 1996 LT-4 car? I have a95 exhaust I fitting to a 96 and it does not have that O2sensor
TIA
Jim
TIA
Jim
Post cat O2 LH on a '96 is in the front pipe just behind the flange to the converter. I believe it's 4 - 6" beyond the flange, I have an LT4 exhaust but couldn't measure it until likely Monday.
In this Corsa install sheet you can see the location of the O2 for LH.
http://www.carid.com/images/corsa/ex...structions.pdf
Where is it presently on your '96 car? It should be quite obvious I'd think if you just looked.
I actually bolted the exhaust up to try to locate the right spot. I wound up putting just forward of the first bend so it would clear the slave cylinder and other crap in the area.
Jim
Jim
