Door Ajar Switch Part
Old 10-20-2014, 06:13 PM
Justpostyourself
Justpostyourself's Avatar
Default Door Ajar Switch Part
Good Afternoon All:
I am having an issue where each time I hit a heavy bump the "door ajar" sign comes on. In addition to this the interior lights come on. My mechanic states that the part has been discontinued via GM and his parts guy. Anyone know how i can fix this issue or anywhere i can get parts?
DANKE! Chris
Old 10-20-2014, 09:07 PM
kevakasper
kevakasper's Avatar
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by Justpostyourself
Good Afternoon All:
DANKE! Chris
Mid America has them! They were out of stock everywhere last year but someone must have re run the production as most places can get them now.
Old 10-20-2014, 09:44 PM
Justpostyourself
Can you help me out with a part #?
I am a bit of a newb to this part
Old 10-21-2014, 02:11 AM
Cliff Harris
Cliff Harris's Avatar
We need a year. The switch changed from this:
to this:
These switches are available from the usual Corvette parts vendors.
Old 10-21-2014, 02:13 AM
Justpostyourself
1994 c4
Old 10-21-2014, 04:14 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
1994 c4
GM # 10098478 which can be used as a reference # at most of the resellers or even eBay.
Old 10-21-2014, 08:58 AM
kevakasper
kevakasper's Avatar
http://www.ecklerscorvette.com/corve...1988-1996.html
Old 10-21-2014, 11:31 AM
davewhtt
davewhtt's Avatar
Good Afternoon All:
DANKE! Chris
Have you tried a little WD-40 yet? They will stick sometimes.
Old 10-22-2014, 01:15 AM
samsonb
samsonb's Avatar
You can try taking out the plunger and putting a couple of small o-rings on the back side of the plunger, then put the plunger piece back in the switch.
Old 10-22-2014, 10:40 AM
Justpostyourself
Thanks all- i will try this first and see if it works!
Old 10-23-2014, 02:22 AM
samsonb
samsonb's Avatar
I don't remember the size. But you'll want an o-ring that fits snug on the plunger shaft, but the outer diameter of the o-ring is same size or slightly smaller than the outer diameter of the head of the plunger. You'll want to still be able to push the plunger inside the housing. Saw someone mention a #60 o-ring size.
You can try one at first. But if you still get some Door Ajar lights, can add on a 2nd one.
Old 10-23-2014, 03:56 AM
Joe C
Joe C's Avatar
- I know the OP has a later model, but I freed up the ones on my 85, with a multi-purpose lube. seemed to work OK. I would have liked to upgrade the 85's, but with the newer parts, and the wiring adapters, I was looking at around $100 for both doors.
To Door Ajar Switch Part
Quick Reply: Door Ajar Switch Part
