Opinions - Advanced Induction or Lloyd Elliott
My point is that "reworked" vs "stock" is NOT an apples-to-apples comparison, nor need it be so. Geardo clearly is saying that having my Trick Flows reworked by LE would be better than using out-of-the-box AFR heads. What would YOU consider to be a valid apples-to-apples comparison?
Valid question, but I assume he is referring to AFR's 195cc heads as they come closest to the Trick Flow 185's. It would be helpful if AFR's website provided information explaining the difference between their "race ready" and "competition package" heads. I couldn't find anything showing whether you're paying strictly for additional machine work, or if the comp package also includes upgraded components. My TF's were basically a starter kit ... assembled heads, cam, gaskets, push rods, roller rockers, bolts, etc. for less than $2500. A cheap way to reel in a new customer. Now that I am officially addicted, the dealer wants me to pay more for the good stuff.
Received 3,043 Likes
St. Jude Donor '05
The 195 AFR comp port is an awfully stout head size for size dont see it real easy for another that size to compare to it. You can order it with HR or SR springs.
Maybe ask tpi421vette what he could set you up in a head like that $$ wise. The 210 comp port would be my choice. Either being a hit really -
What info is around that could convince one a worked tfs is better?
Any data on them, port size features etc? Always nice to compare.
If you are going to compare a ported head to a AFR head, you need to compare the port volume size after porting. I have seen LE take a 195cc LT4 head and the port volume was over 240cc's when he was done.
It was probably 4 years ago.
Do what you think is best for you.Use what you have as is or with a good valve job and some minor porting.See what that gives you.If you are happy then you saved a ton of money.If not sell them and upgrade later.That is the only way you will truly know which is better.
It is easy to over analyze this stuff.All will give good torque and power.Which one depends on a lot of factors including cam and compression.
Build the best bottom end you can afford.
LE recently quoted me a price of $900 to port both the heads and intake. If it turns out that reworked TFs aren't doing the job, it's not a tremendous financial loss ... after all, it's a given that this hobby of ours costs money. But if I ultimately dump the TFs, I'll probably go to a customized head/cam combo from Advanced Induction.
I'm not cutting corners on the motor's bottom end .... the machine work for the block will include CNC blueprinting, surfacing, cylinder boring, lifter bore machining, align honing mains, balance rotating assembly, block decking, stroker crank clearance, etc. The parts will also be top-shelf stuff ... Callies Dragon Slayer crank, CompStar H-beam rods, Mahle or Ross pistons, Mahle file-fit rings, Cloyes dual roller timing set, Clevite bearings, Melling oil pump, etc.
Spending money is fun .... spending MORE money is MORE fun!!!
