LT1 Manifold Conversion - Coolant and gasket questions
Hi all, I just started gathering the parts for swapping out the TPI for an LT1 setup on my '91. I know there's plenty of people who've done this before, I've done a ton of research. There seem to be more people sharing failure stories than success stories, but hopefully there are people successfully running this setup who can offer some guidance.
I think I'm aware of most of the potential pitfalls with the conversion and I think I have the tools to deal with most of them. I'm keeping the stock large cap HEI. I've already started to fab up a plate to help locate the distributor hole accurately and am aware that I'll need a 1/4" thick and 5* spacer for it to sit properly. I also know about the EGR boss clearance issues, remote thermostat, etc etc.
For the record the manifold is off of a '92-'93 vette, I purchased it before I knew that the fuel rail setup is no good for the conversion. I've already ditched the fuel rails as they were corroded on the inside so I didnt want to use/modify them either way. I'm most likely going to pick up a set of later style fuel rails that I'll modify for AN fittings and braided lines. Other than the fuel rail situation, the '92-'93 manifold will still work for the conversion, correct?
Anyways my main concerns lie with the coolant setup and the manifold gaskets I'll need. From what I've read it's easier to tap the rear of the manifold for the coolant lines in order to avoid clearance issues with the TB and TB cables (I'll be using the TPI TB). However I'm not sure what manifold gasket I should be using that will work properly for the modified rear coolant passages. I think that the Felpro 1204 is the proper one to use (for the L98 bolt hole placement) but I cant get a straight answer on whether or not this gasket has the rear coolant "restrictor" holes I keep reading about, and I'm not sure whether or not I need them for the modified rear coolant passages. Can anyone shine some light here?
I'm building this car for track use (HPDE and time trails) and will be upgrading the rest of the cooling system as well (better radiator, new hoses, higher flow WP, deleting the heater core and AC, etc). Needless to say that I want a bulletproof cooling system that will withstand the higher RPM's without blowing out a gasket and grenading my whole engine.
I'm open to all opinions/input here positive or negative, as of now I want to keep moving forward with the conversion but will consider people's opinions if they dont think it's a good setup for a road course car. Right now all I have is the manifold which I got for a reasonable price, so it's not too late for me to go in a different direction if need be. Thanks!
Received 3,043 Likes
St. Jude Donor '05
Should bolt up the same as the later intakes
1204 is fine outside your bolt holes which is an easy fix
Not clear on the question of the rear coolant passages
Dont think you need a blockoff plate the gasket should do it long as it seals. Bet felpro makes one with and without.
My main concern is definitely the rear coolant passages, I don't want to cause a lack of proper cooling on the rear cylinders. Maybe I should contact felpro directly and see...
What's wrong with the 92-93 rails? I wasn't aware that any corvette rails and fuel lines would fit with a standard dist. in the rear. The camaro/impala seems to work but but the fuel lines on the drivers side.
Also another note, I noticed that the gasket surface of my manifold has some gouges in it in a few spots. They're not huge but they are noticeable. I know that's no bueno for sealing, but is it as serious a deal as say gouges on a head gasket surface? Will I need to get the surfaces machined or can I still get a good seal with the proper gaskets and rtv? I'll post a pic in a bit.
I did this conversion about 5 years ago and this is my opinion and this is what I did. I added the coolant lines to the front of the intake by milling off the bolt mounts that were on the front of the intake and then tapping the intake for fitting that ran the water lines out to a remote T-stat. I did this because I did not like the idea of reversing the coolant flow through the head by pulling out the water from the back. I was concerned that the head gaskets would have been designed to equalize flow through the head and block with water being pulled from the front, if I reversed this I was concerned about creating hot spots around some cylinders (#3, #5). I also milled the intake for the large cap distributor but be warned it takes a lot of milling and welding after you are done to seal the EGR passages back up, since they will be exposed to atmosphere. As far as road racing this it should be fine as long as you keep the coolant flowing as designed by GM. When it comes to the distributor spacer I milled in my distributor hole on the required angle and then added in a spacer that was flat and then bolted it into place at the correct distance from the intake. It worked well since the manifold was milled on an angle that matched the distributor so the spacer did not have to be machined on an angle.
I have some pictures of my set-up if you need them.
yakmastermax (03-21-2023)
What gasket did you use? 1204?
Unfortunately I don't have easy access to a mill and I'm trying to avoid machining costs if I can. That said I'm not welding to avoid warping the piece so I'm going to use JB weld liberally.
St. Jude Donor '05
Put up pics of it
Theres always a light dust coat of spray paint on the surface then take a longboard to it to ck flatness. Dont get too carried away with rough grit
Its a little old school but will tell you what you want to know
St. Jude Donor '05
Hey oz how do you like that thermostat housing?
Does it use an oring?
Have a cast alum piece they all seem to deform and leak once you snug them down even after excluding the oring making them flat and using a gasket.
Not deep at all, but long gouge here on the front of the piece.
These are the two worst ones in terms of depth. Notice the long gash on top and the shorter wider gash near the bolt hole. This is at the rear of the piece.
Notice the gash connecting the bottom of the two ports. Again not super deep, but this location worries me the most for gasket sealing.
What do you guys think, am I better off having the surfaces machined? I know only a tiny bit can be taken off, but I want to avoid fitment issues obviously.
I also didnt know that Moroso piece existed, it seems like a very clean way to integrate the remote thermostat. How's the quality of the piece? I know Moroso stuff can be hit or miss.
Also, what WP are you running? I made the call that electric WP's wouldnt be the best choice for consistent high RPM road racing unless I got the most expensive highest flowing pump, so I'm looking at a more budget friendly Stewart Stage 3 WP.
Drool! That's a very cool setup, I like looking at all the custom single plane setups around here.
The moroso unit is machined from billet, so its pretty strong, I used 2 x -12 O ring fittings (going down to -10 for the hose fitting) and the water neck is an O ring 360 degree swivel, there has not been a hint of leaking so far, the moroso unit is good value at $70. you can use either an o ring neck or a flat gasket neck with it.
I was a bit dubious about the O ring water neck sealing, but its a pretty solid piece and there is no flex. there is a big price difference in those water necks, maybe the more expensive ones are better ?
Im running the GM C4 water pump, with a wet and dry polish, I did have another pump in there (some generic brand) but the GM pump cools better at slower speed.
St. Jude Donor '05
Thx sure its worth the extra dough
Dont think that gash would cause an issue touch of sealant and youre good making sure its straight, why not
