Trying to build up the courage to replace the heater core.
UPDATE! It's Done! Trying to build up the courage to replace the heater core.
It should arrive via Amazon tomorrow. It looks like Sunday is D-Day for tearing this thing apart. It's a 1994. I'm terrified!
I did watch the video in the sticky section. I have an airbag to contend with as well. Any other reccomendations/tips? Do I need to remove the radio?
Thanks!
Thanks!
There is a lot to deal with. Having a factory service manual will help a lot...unless you trust watching the video.
I will write this....I do not care who it came from...but I would take it to a radiator shop and have it checked...and sometimes have my guy add more solder to make sure the tubes are stout.....WHY do I write this.....BECAUSE go ahead and put it in only to find out that there is a small leak where the tubes are soldered...and you have to do it all over again. TRUST ME...I am writing this FROM EXPERIENCE. I do not TRUST any of them...they ALL get checked before going in. I made that mistake ONCE!
DUB
DUB
That's good advice from Dub. Yeah, you will burn up an afternoon or something having it checked, but if you are overwhelmed now, then you don't want to do it again.
Don't look at the scope of the job and think OH ****. It's just nuts, bolts, screws, plastic and stuff. You aren't modifying anything. You just take it apart, then put it back together. I like to tag and bag. Meaning, take a screw or bolt or nut or whatever and put it in a bag that is labeled. ziplocks work as well as paper "lunch bags". I've messed up before and thought, Oh I can remember all this. But then something happens and I don't finish the job right away and then I don't remember where it all goes. Take pics with your phone. It will give you some confidence that it is all going back the same as it was. Just get in there and get dirty with her. Good luck!
DUB
DUB
I did mine, its involved and I would suggest that you do it on Sat...incase you need an extra day. Don't forget the monkey $hit to seal the area where the inlet/outlet pipes exit the fire wall.
Tommy
I say winter cuz I live in Az and the temps are much cooler and mine needs to be replaced before our lovely summer hits us!
I made the video, so I can definitely give you tips. The radio can stay in the dash, but the tuner and second fuse block under the passenger side needs to come out. Really easy to remove and it will save a ton of hassle. Aside from the stupid defroster pipe and trying to reinstall the cover with the tuner/fuse block in the way, it wasn't that bad of a job.
I was just the test dummy that spent 3 friggin hours trying to figure that crap out.
Just finished this repair myself on my 94. I did remove the dash pad, air bag, knee bolster support that has the wiring harness zip tied to it and the triangularish support on the passenger side to give myself some wiggle room which came in handy. Wasn't much more work to get those parts out and made the actual repair work a bit easier. All in all it was a long process. I'd say the hardest part was not breaking plastic tabs that hold things together. Of course I failed horribly at that part. Also, take the seat out and have a towel or something handy under the heater box when you break it open as some old dirty coolant will likely leak out and you don't want that on your carpet. I also recommend plugging the heater core tubes with some cork or even taping them up as again coolant can spill out when trying to maneuver it out of the heater box. Its a long tedious process but not impossible.
Edit: If you unplug the two large connectors under the dash that look identical. Make sure you plug the right one back into the right receptacle. I mixed these up because I was tired and rushing to finish. Now I'm having issues with the security system that may or may not be related. It was acting up before but only once in a while. Now it seems to be persistent.
Thanks, the video was helpful. Mine is a 94, so the airbag posed a problem. I didn't take any of the wiring out at all, I didn't even take the entire plastic box off of the core. I couldn't get to the top screw without talking the entire dash/airbag out and I didn't want to do that. It took me about 7.5 hours all told. It was absolutely the worst car repair I've ever done. Does GM sharpen the bracket that holds the heater core in? It seems like it, it looks like I've been in a fight with a mountain lion. Anyway, it's done. What a relief.
DUB
DUB
The shop might also best advise you as to a repair or replace.
YES to the check of the new before install and be dammed sure it's the correct one before starting the job. If there's a very talented radiator repair, gas tank repair shop in the area I might maybe consider the repair of the OE vs. the replacement with any after-market. The repair shop maybe also might have a "preferred" brand.
