Starters & Headers...To wrap or not to wrap?
So...I've spent about the last 2 hours reading the forums about people wrapping or not wrapping their starters.
Long story short, I was going down the road the other night and started smelling something burning...oh SH**, right?!? So, I pop the hood to see smoke coming from under the hood...always a good sign, I know. Nonetheless, the starter wrap shield was lying right on the headers and you could see where the foil material was getting burned.
I will tell you the car has the 2149 Hooker headers that are just the regular black tubes. To be honest, when I do drive the car, its maybe 10 miles at a time. This last Friday night when I took it out, I went on an extended road trip and drove her about 20 miles...went all out huh? So, I saw it was the header wrap and drove it home. Tonight I went outside to see what the situation was and I decided to remove the shield. Talk about a PITA taking it off...I can only imagine putting it on.
I didnt put it on before...when I had the motor out putting heads, the cam, headers, etc on it, thats when they wrapped it. So, obviously we all know how close the starter is to the header. Ive read people saying dont wrap it b/c it keeps the heat in and just leave it open to breathe, others saying to wrap it to keep it from frying, and others saying to just wrap the headers. I will say that is not an option b/c it is a show car and wrapped headers aint gonna cut it. Lets be honest, wrapped headers arent usually show quality. Drag or race car, sure...trailer queen, aint happenin'.
So with all this said, I'd like to hear everyone opinion to see if theres some options I havent thought about. Thanks!
I installed an insulated sheet metal heat shield on my starter, that allows air to circulate around the starter, but blocks the radiated heat from the exhaust. Looks good, works fine, and is an available part for Delco starters. Wouldn't be hard to make if you've got one of those fancy high-torque starters. You'll appreciate an added plug on the starter wiring, to make installation and removal easier.
I agree, the insulated wrap isn't much help.
Received 1,400 Likes
I would never wrap anything. I would just get the headers recoated to help with the heat.
When I got my Hedman Elites, the warranty page said that if I used any wrap on the headers, it would void the warranty.
It's possible that header wrap could hold moisture and eventually that could cause rust to form
I would suggest removing the headers and have a coating installed. I think Jet-Hot is still around and I remember that they did good work.
Received 3,043 Likes
St. Jude Donor '05
Not a fan of that header wrapped if it gets oil soaked no bueno
Even with mini starters I use that Heat shield stuff from Summit wiht the stainless clamps. One no start is too many. Takes 20 min to cut up and put on.
Pass on the wrap. Over a few years time it will trap and hold in any water/condensation. Get your headers coated and add that heat shield to your starter for sure.
Later,
Lee
Later,
Lee
I ran a set of wrapped headers AND painted them with the paint made for that purpose, for many years. All the hooha I heard about "crystallized headers" and such was untrue. When I removed them for this engine, and unwrapped them, they were fine... BUT
I'll never again employ headers that are not hot coated, hopefully inside and out. It's cleaner and looks better, much longer. The wrap did improve seat-of-the-pants-measured header efficacy, quite noticibly.
I have a starter blanket that worked so well, it's been in a garage cabinet, looking like new, since about 20 minutes after I installed (un) it. It excelled at keeping the mini-starter hot!
IMO from personal experience the use of header wrap can really help. But like anything else that will depend on if it's installed correctly. If you leave the headers on the engine & attempt installing the wrap. Well, odd's are great that your going to end up with a half *** job that's going to end up as a waste of time & money.
But, if you truly take the time for removing the headers & wrapping them in the correct manor, along with securing it correctly. It will be worth while and give the results your looking for.
On the down side your going to be dealing with the burn in smell for awhile & as stated above use caution when dealing with fluids that could drip or spill on your wrapped headers.
Rule of thumb is that coated headers can be wrapped. Uncoated headers will fail prematurely if wrapped.
