94 coupe where are all fuses relays for antenna and radio box- amps
my antenna wont go up and down and radio just buzzes. worked fine couple days ago and has new gm replaced antenna.
do these two items share the same fuses or relays? 1994
bose gold system
bose gold system
The buzzing is likely because it is not getting a good FM signal due to the antenna not being up. I would chase the Antenna problem (fuse or motor) first and see what happens with you get that fixed or even rigged to have a signal (long coat hangar).
