'94 '94 Convertible story & 1/4 mile times at Rockingham
Old 11-15-2014, 06:45 PM
jonecap
jonecap's Avatar
Default '94 Convertible story & 1/4 mile times at Rockingham
Old 11-16-2014, 11:41 AM
rklessdriver
rklessdriver's Avatar
Thats a really good ET. 108 MPH indicates the motor makes good power.
3.07 gear would get it in the 12s now but it's November and the DA is always exceptional at the Rock this time of year.... so you know that it will fall off some come next spring.
Glad you're back in a Vette and the GN is a cool car too.
Will
Old 11-16-2014, 02:02 PM
STEVEN13
STEVEN13's Avatar
You always go fast and quick with your stuff.
Good to see you back in a C4
Old 11-16-2014, 02:22 PM
neat
neat's Avatar
The Corvette shaped horseshoe he has stuffed up his *** is, apparently, still installed.
This fool, from the woods in NC, has accomplished the following:
LT4 - probably the fastest stock head LT4 car ever, 10.72 @ 128.
02 Zo6 - second fastest stock car ever. 11.5 @ 117. Only a few hundreths behind the record, despite being 3 MPH slower than the record holder.
94 Covertible - probably the fastest stock car of it's type.
What. The. ****.
Old 11-16-2014, 04:13 PM
jonecap
jonecap's Avatar
Old 11-17-2014, 02:13 AM
JC316
JC316's Avatar
108 trap speed on a stock car with only 261RWP? Am I the only one that's calling BS on here? A C5 traps 109 with 300-310RWP. The 13.8@101 looks much closer to what a C4 vert auto should run.
Old 11-17-2014, 08:01 AM
jonecap
jonecap's Avatar
Old 11-17-2014, 11:28 AM
Vic'89
Vic'89's Avatar
Originally Posted by jonecap
I put Magnaflow mufflers on it, a 160 degree thermostat, airfoil, and personally tuned it on a dyno. I just paid for dyno time and dialed in a bit with TunerCat. It ultimately made 261rwhp/291rwtq on a DynoJet.
This setup seems right in-line with other Stock LT1's I have seen race, low 13's.
You can go low 12's with 3.73 gears and a nice 3000K stall convertor.
Nice job, not sure why someone is calling BS on this.
Vic
Old 11-17-2014, 12:27 PM
93 ragtop
93 ragtop's Avatar
Vic
I tend to agree. I can tell you when mine was stock other then 3.54 gears and 3000 stall converter, On mich. pilot tires I ran a 12.91 at 105.xx on a hot summer day. At the same time my friend had a 94 coupe 3.07 gears bone stock with goodyear tires. His ran 13.23 at 105.xx
Since then my experience has shown getting the engine as cold as possible helps, which you are doing. On a -1300 da day, I believe you are telling the truth.
BTW If I had it all to do again, I would find a dana 44 3.45 gears and swap. I broke the 36 with street tires. If cost is no object 3.73 on a stock motor would be my choice. Gears will make it a totally different car. Much more fun to drive.
Old 11-17-2014, 01:46 PM
JC316
JC316's Avatar
You can chose not to believe it if you want to, but those are the times that the car ran which is why I made the thread in the first place. I know they are very good times for this car. However, since you are doubting it, here's some more info:
1. The Density Altitude (DA) at the track was -1341 feet when we arrived and was around -1,200 most of the day. That's the same as running 1,200 feet below sea level. That sort of DA is almost unheard of in NC. In 20 years of going to the track, the previous best DA I've ever seen was -750 feet, so the air was VERY good. If you use DragTimes DA calculator to correct that ET and mph to sea level, it corrects to 13.29 @ 106mph, which is still not bad for a stockish convertible with a 2.59 gear.
2. I've owned and drag raced 3 different C4's over the years. The first was a 1990 6 speed car, which I did full bolt-ons to. That car made 277rwhp and trapped a best of 107.5. However, it was out of breath at 5,000 rpm, so it didn't make that power for very long. The LT1 in the '94 pulls a lot longer at 261rwhp than the '90 did at 277rwhp, so it's not surprising that the trap speed is close.
The second C4 was a '96 LT4 that I raced for many years. In stockish form, it made 304rwhp and trapped 111mph on drag radials. So 108mph is not really surprising at 261rwhp. The LT4 ultimately trapped 118mph at 354rwhp after mods.
3. I weigh 152 pounds, so I'm not slowing the car down much. All other unnecessary weight was removed from the car. No spare, jack, etc. Also, after drag racing street cars for many years, I'm good at getting every bit of possible performance out of them at the track.
4. The '94 convertible has new Nitto NT555 radials on it (NOT Drag Radials). I was able to launch the car on the mat and it didn't spin. It was not leaving any usable power on the table.
5. The 13.8 at 101mph was Neat's Fox body Mustang. That car ran 3-4 tenths of a second and 3mph faster in the good air at Rockingham than in previous track trips with no other changes. The DA was VERY good.
Believe it or not
Makes more since with that DA. I'm not used to seeing a stock LT1 trap LS1 speeds in my area, but I am in Texas and it's usually hot here, so the DA is in the crapper. Also used to LS1tech where the racers are completely full of crap. You clearly aren't, so sorry that I called BS. That is a VERY good time for a heavy vert.
Old 11-17-2014, 08:03 PM
856SPEED
856SPEED's Avatar
108mph on a stock LT1.........VERY IMPRESSIVE INDEED ; 261 rwhp
I've seen that mph with more rwhp and similar weight.
Old 11-17-2014, 08:07 PM
tpi 421 vette
tpi 421 vette's Avatar
With more gear in it, it would easily run 12's. Nice job
Old 11-17-2014, 08:34 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Jonecap and neat are credible theyve been at it for yrs
Optimizing the car itself and driving...plus an amazing DA can put a # out there that may make one think their times for real.
Avg driver in the air out here would be slower than most on the web.
Its all subjective and cant always be judged off rwhp thats why i dont pay much attention to dyno #s and projecting times it doesnt mean much at the end of the day.
Old 11-23-2014, 12:06 PM
neat
neat's Avatar
Thanks Ron.
Have you heard from Mick lately? I've been working on catching up with him for over a year and can't seem to make the connection.
Old 11-23-2014, 12:09 PM
cv67
cv67's Avatar
St. Jude Donor '05
Talk to him quite often
He sold his C4 and is working on a pretty over the top Camaro project
Give him a ring.
Old 11-23-2014, 12:21 PM
1993C4LT1
1993C4LT1's Avatar
Awesome 1/4 time My first C4 had the 2.59 gears, the C4 I have now, has the 3.07. It feels slightly faster on take off.
To '94 '94 Convertible story & 1/4 mile times at Rockingham
Quick Reply: '94 '94 Convertible story & 1/4 mile times at Rockingham
