charging problem, chances of two bad alternators?
#41
Yes for sure some new "SI" 86-91 alternators are garbage, i have come across bad tolerances. Bearings not gripping the shaft, the shaft can move back and forward which means the brushes will not contact the communtator and charging stops. You will notice tapping the alternator with a screwdriver handle will make it charge again.
I got sick of replacing new reconditioned alternators, fitted a powermaster and have not had any issues since that is many years ago the voltage at idle is also so much better.
200 Amp New Alternator Chevy Corvette 1988 1991 High Output Generator | eBay
So having no voltage a terminal "L" doesn't mean anything then?
My DIC hasn't lit up since I've owned the car which makes following the next part of the troubleshooting guide difficult because it wants me to jumper a wire and see if the indicator lights up.
I currently have the DIC out to check bulbs and determine why it doesn't light up. According the the FSM if the DIC AND gauges don't work then it is the CLSTR FUSE. But my guages work only the DIC doesn't. The buttons for trip/fuel/eng/met all work but they are on a separate circuit.
I swear I hate electronics!
#42
so after doing some more research it appears as though the "L" circuit is merely grounded by the alternator and if the charge indicator doesn't light up the problem is elsewhere. This circuit would not affect the charging status of the alternator.
I believe I may have a problem with the fusible links. I will try and check those tonight or tomorrow night.
#43
You may want to have a closer look at your 90 manual.
My 86 manual shows that terminal "L" is the field wire, which turns "ON" the alternator.
It gets power from ignition switch through a resistor or resistor wire. Terminal "S" is the sensing wire, which senses if there is more output required.
#44
Speaking of which, I did manage to find out why my information center doesn't work.
#45
I used to convert those alternators to run on older vehicles. I'm pretty sure the L terminal has to go through either a light or a 33 ohm resistor to get the alternator to charge.
So in a stock application you might check that the wire is not broken, etc. Maybe run the L terminal through a resistor to 12 volt temporary and see how it works. I know they wouldn't charge at all with nothing connected to that terminal, and something as simple as a light bulb would make it.
#46
Your saying that it needs resistance on "L" to charge? The latest alternator charges like mad for about 20 minutes (audible noise) and then shuts off. Like it overheats or detects an overcharge. I can shut the car off and come back a while later and it will do the same thing.
Here is the circuit I am working off of.
#47
The information center has a broken ground circuit for all the bulbs - I'm guessing that's why it never worked in the 12 yrs I've owned the car. But that would also mean that the "L" circuit has never been complete. I have battery voltage from "F" and "S."
#48
Did some google of your CS 130 alternator. Didn't find any info on 4 wires to alt, just the fact that "L" is what turns on alt, by getting 12v from ignition via warning light. It seems that the bulb itself is being used as the resistor, so you would need to fix the open in that circuit.
Could be the bulb is burnt or the 5 amp cluster fuse is blown.
#49
Yes, there are four wires to the alternator. 3 are in a harness plug and consist of the "L" "S" and "F". The 4th wire is a larger wire that connects to a terminal on the back of the alternator and runs straight to the battery. (See pictures on page 1)
Fuse and bulb are both good. I have the unit at a repair shop where they are attempting to solder it back together. But again - the DIC hasn't worked in the 12 years I've owned the car so why would it matter now?
#51
#52
problem solved. knock on wood.
Alrighty, well here's something that I haven't seen in all my time owning the car. The DIC working..... I took it to a guy at work and he was able to solder the broken ground. I put the dash back together and went through the troubleshooting guide again and everything tested fine. Started the car and went on a 2 hr drive and not once did it act up! !!
I still can't wrap my head around how/why that works but hey, I have my vette driving again! Thanks for all the tips and suggestions!
