85-89: Location of cooling fan temp switch?
Hi,
I hope my question is simple: Where is the "cooling fan temp switch" located if a '85-'89 C4 is equipped with the B4P-option (dual fan)?
So a non-B4P Vette does neither have the switch nor the dark green wire, right?
Bigdick (01-19-2021)
Hi
The temp sender is between cyl 1 and 3. The temperature overide for the booster fan switch is between cyl 6 and 8. on my 85
The Ecm controls the main cooling fan via the engine temperature, it will turn the main cooling fan on at around 228F
The booster fan comes on at around 235F (don't quote me on this is a rough guess we Ausies use celsius not farenheight)
The switch for the booster fan a has a big round clip, the temp sender is a flat spade one.
