Belt Routing for 91 Corvette without A/C or EGR
Hey guys, looking to remove the A/C & Smog on the 91 L98 corvette.
I saw some posts... and it looks like there is a way to run the stock waterpump, and leave the alternator on the drivers side, but I'm unable to see a clear answer on what parts are required to accomplish this successfully.
Would appreciate any info here and where to get everything.
Thank you,
Dave
Thank you,
Dave
Dave,
I've attached two pictures that show the AC / Air pump removed and replaced with the TPIS conversion mounting hardware. I also used a shorter (-1") drive belt as the original had very little tension. I will agree that you could through something together for little or nothing, as the TPIS price on the conversion hardware is a little spendy, but it works very well.
https://www.corvetteforum.com/forums...1&d=1416665248
Thank you Vett1990, that is exactly the setup I ordered from TPIS, much appreciated!
Thanks,
Dave
Thanks,
Dave
Dave,
