Head Light Motor Noise 1992 C4
When the headlights are turned on, they both open no problems but the motors continue to operate for about 5 seconds and makes a knocking noise. The headlight operation is smooth and the noise only begins when the headlight has reached the fully open or closed positions. What could be causing this?
If it opens and closes but you have motor run on it's not the gears. The motor should shut off after its job is done. Could be headlight control module or headlight switch in the car. My old headlight motor did this and the internals were like new.
Check this video. He starts out with demonstrating the noise that is the problem:
How to change the headlight motor gear in a C4 Corvette - YouTube
What one did it end up being and how did you repair?
It looks like its coming down to the switch. With the new motor it would only open, after the module it open and closed but still have run on. I took the motor to the other side and plugged it in and it works flawlessly so its got to be the switch.
Damn... I would think a switch issue would impact both sides. Where is the module located?
