C4 Cracked rear spring replacement
4th Gear
I have a 1989 6 speed with only 80k miles that started making a noise in the rear area.I rolled under the car and noticed the rear spring was cracked and splitting.I checked my spare parts and had 3 different springs,a RHY from a 96,a BMF from an 84 and a NYR from a 90.You can see the difference in the arch in the picture.After reading some posts I decided to replace with the NYR which is what was in it anyway.I know that something had to cause the spring to crack and after careful inspection found that the u joints were bad in the halfshaft on the same passenger side but only after replacing just the spring.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I have read that it can happen from exhaust heat, using de-greaser to clean the suspension or an accident.
