FIRING ORDER- NO. 1 ON THE DISTRIBUTOR
Ok I have my Haynes book and am well aware of the firing order but
how can you tell which is the number 1 on the distributor ?? Ever since I changed my wires cap rotor and coil, the car is idling like I have a lumpy cam with gas just shooting out of the exaust.
Cruise-In II Veteran
Re: FIRING ORDER- NO. 1 ON THE DISTRIBUTOR (88TripleBlackConvertible)
Use an Ohmeter to ring out the wires; likely two are crossed.
Crank the engine till the timing mark is at TDC and see where the rotor is pointing. It should be pointing at the left front wire terminal.
.........REAR
.......6.........5
3.....................7
4.....................2
.......8..........1
..........FRONT
.........REAR
.......6.........5
.......8..........1
..........FRONT
Re: FIRING ORDER- NO. 1 ON THE DISTRIBUTOR (65Z01)
.........REAR
.......6.........5
.......8..........1
..........FRONT
.........REAR
.......6.........5
.......8..........1
..........FRONT
Actually there is a good diagram in the Haynes manual. I used it when I pulled my cap and replaced all the wires. Take your time and you should be OK. Mine came out perfect.
.........REAR
.......6.........5
.......8..........1
..........FRONT
.........REAR
.......6.........5
.......8..........1
..........FRONT
That is a great diagram
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Number 1 is where ever you want it to be, you just have to set the distributor in for that position
Assuming you have the distributor in the stock position, number 1 is just forward of the housing for the wires that lead to the cap
Jack
Jack
Re: FIRING ORDER- NO. 1 ON THE DISTRIBUTOR (jackdaroofer)
Jack
Jack
The engine doesn't car where you place the #1, as long as all the remaining wires are in the correct order AND the rotor tip is pointing at the #1 when the #1 piston is at TDC on the compression stroke.
I'm betting that you have two wires crossed. That's where I'd check first to solve the bad idle problem
Hope this helps.
Jake
