Which stand alone edit system would u buy
Was wondering which system you guys would buy. I have a 88 vette with a pretty stoudt 383 in it. I'm going to bracket race it but also take it to cruise night and car shows. Was thinking of the fast ez Efi unit or the Holley hp. Both can be tuned by hand held or lap top and also can self learn when hitting the car shows. Guess I better brush up on how to tune. Thanks for any input. Pipe
I have heard good things about the fast ez efi system and I am leaning toward that with my current 406 setup. I am now using an ancient ACCEL gen 6 unit which works fine, but I might be leaving a few tenths on the table. My C4 is also a bracket car.
sorry for the mis spelling
was supposed to say which Efi system would you buy stupid meThanks for the reply Willie I kinda like the EZ efi system also. My friends say go with a carb. It came with injection so im going to keep it that way. The Holley stand alone kit is $1500 for the hp the Fast ez efi kit $835 Willie I LOVE YOUR CAR MAN its SWEET. Wish I would have gone bigger cu in Pipe
I was thinking about going that route a while back, but was also considering the Holley Averger Efi, because the computer can be laptop tuned (uses the same computer as their better efi units, and can be made to run the distributor timing as well. The older Ez-Efi cannot do that, and the new version cost a lot more that the old one.
Thanks for your input Willie a friend of mine took off his stock fuel injection system and put on a carb and said it was a second quicker. I like your trophy room my trophies fit in a small shoe box lol I live about 10 minutes from maple grove drag way in reading pa. I'm always there. Pipe
Pipe have you ever thought using a harness and ECU from a 96 vette. It's an OBDII and programable, and you can trigger the distributor with the opti wires, plus you can add the coil packs. A stout engine will love the extra spark. I would have done that to mine if I had thought about it before I did the LQ4 swap.
Randy
Randy
..... I used the Holley Commander 950 for years ... its very easy to tune via laptop and it controls timing as well ... very affordable and readily available used ... I briefly used the Avenger ECU ... the self learning aspect is great for those hard to get to RPM vs Load areas of the map and I am now using the Holley Dominator mainly because of the switch to a 4L60E transmission ... the Dominator controls that also ... Holley's Tech service guys are VERY good and available on Saturdays as well ..........
Thanks for all the replys everyone. What happens to my stock ECM now doesn't it control some of the dash functions. Also the 88 had the esc and other items I'm not going to use. The car also had the 4 plus 3 trans in it and is changed over to the 700r4 I think that trans needs an electrical connection somewhere in the wiring harness. Was just wondering so many options to think about. Thanks in advance. Pipe
Intl Council of Corvettes
I am running a Holley HP on mine with no issues. I would go for the Dominator unit though because it allows for tranny control if you need it plus other provisions for adders and yes the self tune thing is great. I can hook up my laptop via USB and get real data and make changes if I desire... no issue. The 700R4 does not need the computer for anything and the speed is read straight to the odometer. I just switched from the 700 and went to the 4L60E with a stand alone controller for trans. I run the compushift and it works great as well but if I could turn back time I would have just picked the dominator and been done.
This chart shows the ECM connections for a 700r4:
http://home.earthlink.net/~cliff_har...s/pinouts.html
See pins A7, B10 and C7.
Really appreciate all the replys. I better choose the easiest one to use and tune. Buying stuff for the ford 9 inch install now. Jenkins old driver is double checking my engine building skills to make sure I didn't screw anything up. Merry Xmas guys pipe
