TPIS mini ram install on a 1990; coolant lines?
Old 12-08-2014, 01:13 AM
Danspeed1
Danspeed1's Avatar
Default TPIS mini ram install on a 1990; coolant lines?
Hello,
As the title states, I installed a TPIS miniram on a 1990 corvette. Car was apart for sometime, and I can't remember where all the lines go. The major issue actually is the coolant line that runs to the rear of the TPI manifold. There doesn't seem to be a port on the miniram in the rear. Whats the deal?
Any pictures would be greatly appreciated,
Thanks!
Old 12-08-2014, 10:11 AM
JackDidley
JackDidley's Avatar
I just cut the little hose off short, stuck a stud in it and clamped it. That was about 10 years ago. You are going to love the Mini, I got .3 out of it in the 1/4. That was over an aftermarket TPI.
Old 12-08-2014, 10:52 AM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
That hose was added in an attempt to even cooling of our aluminum heads. It wasn't originally there and has been debated as effective. Not a problem to remove that "T" from your cooling circuit.
Old 12-08-2014, 10:31 PM
Danspeed1
Danspeed1's Avatar
Oh, interesting. So we are clear, that rear hose is a 1990 only attempt at helping to cool the engine, however previous cars did not have that hose and never had an issue? I just want to make sure i am not going to run into any overheating issues or warp the heads.
Thanks for the info!
Dan
Old 12-09-2014, 08:24 AM
WW7
WW7's Avatar
Dan
It's not 90 only, my 89 had that hose also...But when I installed my new motor I deleted the hose and have had no problems..Gm made quite a few "half azz" attempts at fixing things that should have just been left alone on the C4 Corvettes..Like running coolant through the throttle body , and putting a giant steel disk on the water pump.......WW
Old 12-09-2014, 11:06 AM
GREGGPENN
GREGGPENN's Avatar
Of course, sometimes there really was a problem -- that cut into profits with warrantly claims. Possibly the best explanation of what GM was trying to correct with that hose (and eventually did via gasket redesign) is written in this post:
https://www.corvetteforum.com/forums...post1585727929
Old 12-09-2014, 10:28 PM
Danspeed1
Danspeed1's Avatar
Actually, that water pump disc never made it back on the motor after my rebuild. Not quite sure what the purpose was. Figured it was some sort of unnecessary balancer or a poor attempt of keeping the belt on.
DG
Old 12-10-2014, 07:36 AM
WW7
WW7's Avatar
DG
The disk, or (Frizbee as we like to call it) was to dampen the sudden surge when the a/c would kick on, this would cause a jerk motion in some cars according to what I've read...Most have removed it, with only a few noticing any difference at all....WW
Old 12-10-2014, 11:26 AM
GREGGPENN
GREGGPENN's Avatar
And think of it this way....
Have you ever noticed discussion of heavier versus lighter flywheels? Heavier ones are installed for a reason. They add weight (inertia) to the motor. As you engage a clutch, that inertia helps the motor keep spinning and resists the tendency to stall.
Lighter flywheels require a bit more revs/fuel to accomplish the same inertia. OTOH engines with lighter flywheels spin up faster because they don't have to overcome that inertia.
At an idle, that weight must have helped resist engine shudder. On ZF motors, the extra heavy flywheels provide enough inertia on their own. On automatics, the idle speed is set a bit higher. I don't know if the Frisbee started after 84 (or 85), so you gotta wonder exactly which motors it really helped?
To TPIS mini ram install on a 1990; coolant lines?
Quick Reply: TPIS mini ram install on a 1990; coolant lines?
