Refinishing my 3 piece Shelby Series 1 wheels
I have started the process... The wheels are in great shape but peeling from the centers in a couple of spots. I plan on redoing them myself.
I have redone wheels in the past but never a 3 piece. The plan is to take them apart strip the centers and either repaint or polish them. where they are peeling the finish looks pretty smooth underneath.
Any advice would be greatly appreciated.
I figured i will do one at at time so with a E10 socket I took all the bolts apart. I drew an indicator line at the valve stem to realign it afterwords. I then cut the silicone bead with a razor and with a rubber mallet they came apart very easily.
Years ago I had some aluminum wheels that were not coated. They oxidized over time and turned black. I had to polish them about every 6 months. Not coating them is OK if you are willing to do the maintenance...
I also like the bare metel look, but your going to have to clearcoat them to stop the oxidation....Good Job, I didn't know you were so talented........WW
I don't know that it's important now or not but if you were to want to change brake options later the centers could require relocation to the outer of the rims. It might be interesting to measure back-spacing/offset assembled both ways. Also if there were any reason to maybe change the tire/wheel placement in the wheelhouses now might be the time to determine that. Scott's are assembled that way and he mentioned in the other thread it was required for the C5 brakes?
I don't know that I would have separated the rim-halves but it's done now.
If you opt to go the rattle can route, I recommend
VHT Paints 11 Oz. Clear coat wheel paint (part number SP184). Four wheels took 2 cans. Bought the paint at Autozone for $6.99 per can. VHT also has a silver wheel paint if you want that look. I bought both but returned the silver as the aluminum polished up fine and is well protected by the clear coat. Was a good choice for me as that was last July and the rims on my son's Integra still look great.
