Bolts For The IAC
Bolts For The IAC
Hey everyone. If you've seen my other posts, I just changed my fuel injectors, TPS and IAC. The reason I changed my IAC was because I got a P0507 code high rpms. Now with the new IAC, my rpms are manageable but still alittle high. The rpms are at 1000 instead of 600-700 and still getting code p0507. This time, I'm going to take off the throttle body to clean it and the IAC passage. The question is, does anyone know where I can get the 2 torx headed bolts for the IAC or what can I use to replace them because one of the torx heads is starting to strip.
Have you got a "Fastenal" or some sort of professional store around you?
