Banski or VBR rear toe rods
Old 12-28-2014, 04:07 PM
vstol
vstol's Avatar
Default Banski or VBR rear toe rods
Banski Aluminum read Toe rods for $360 or VBP DOM for $299
Old 12-28-2014, 04:13 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
I would do Newman Creations and I would have likely have done their front control arm package as well as the balance of the rear suspension arms. I have NOS GM stuff or I would certainly consider his stuff above all others:
http://www.newmancarcreations.com/products/
Rear toe is near the bottom of the products link. Newman is first class components.
All I can mention is make the call and talk to him. I've had many good discussions with him regarding several things.
Old 12-28-2014, 07:01 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
What do these rods do that the stock ones don't?
Old 12-28-2014, 08:22 PM
vstol
vstol's Avatar
replace the old worn out ones
Old 12-29-2014, 08:53 AM
astock165
astock165's Avatar
I'd recommend the Banski kit. Although a little more money the rod ends are Teflon lined and therefore very low maintenance as they don't need to be greased.
In addition the locking mechanism uses clamps rather than jam nuts and only requires a small 1/4" socket or 3/16" allen wrench to tighten, as opposed to two large wrenches for the jam nuts.
The center mounting bracket and suspension knuckle threaded studs are all stainless steel to reduce corrosion.
There is also a "safety plate" used with the center bracket that puts the inner rod end bolts in a double shear condition rather than a cantilevered condition.
Old 12-29-2014, 08:56 AM
astock165
astock165's Avatar
From a functional standpoint they do essentially the same thing. IMO, the Banski kit has a better locking mechanism and uses dry lube rod ends as described above.
Any rod end kit will also make it easier to change the inner tie rod end(s) if they were to wear out. You can change just the rod end rather than having to buy the OE center assembly.
Admittedly I might be a bit biased however.
Old 12-29-2014, 12:12 PM
vstol
vstol's Avatar
Thanks for your comments, Teflon lined is a plus
Old 12-29-2014, 02:25 PM
blue94
blue94's Avatar
I have had Banski kits with DRM mounting brackets for a few years now and the ride is much better. Just make sure to get the boots for a DD to keep dirt out.
Old 01-03-2015, 10:48 AM
vstol
vstol's Avatar
thanks
To Banski or VBR rear toe rods
Quick Reply: Banski or VBR rear toe rods
