crushed fuel return lines?
Oil Producer
Hi guys. I am wrapping up my 85 bright red coupe
repairs and i have a question regarding the fuel lines.
I THINK these are the fuel tank return lines (why are there 2?).
This is a pic of a previous owners mistake of putting a jack here and crushing these lines.
so,
1. what lines are these? What do they do? do i need to fix? i was going to use rubber hose.
2. what would the symptoms be from the current condition?
im asking because i have a hesitation off the line (only in overdrive) and also the car seems to be running rich (exhaust burns my eyes).
wondering if these are linked.
ideas?
these 2 lines are rear driver side and smell fuelly.
they appear to have been crushed probably by a jack.
so,
ideas?
Oil Producer
i am just mentioning thus because you called one a "fresh" line.
Is that right? seems strange for a fresh line to be there when the filter is under the passenger side.
Not necessarily -
The OP's car is an '85 so there's no ABS. I believe if the OP checks further one pipe will be 3/16 and the other is 1/4. The 3/16 will be a brake line and go to a fitting that supplies both the left and right rear. The other the 1/4 will be the fuel vent pipe. I believe the fuel vent line is on the left side for many years until the canister was moved to the rear.
so,
ideas?
so,
ideas?
they are the fuel supply and return lines, just changed/replaced the return on my 90. I used rubber fuel injection rated 3/8 hose for the return. ran it from the return connection on the fuel tank, down and along to where the ruptured line section was. I removed the ruptured section along the bottom of the car.
Oil Producer
Thnx for the help guys. ill be under the car again tomorrow. just to clarify, the leaking lines in question are on the LEFT side, by the parking brake equalizer.
