??? - hole location 86-91 C-beam exhaust hanger
Old 01-04-2015, 05:07 AM
Joe C
Joe C's Avatar
Default ??? - hole location 86-91 C-beam exhaust hanger
trying to work thru a brain fart - installing an 86-91 corsa cat back system on my 85 corvette. there is an exhaust hanger that mounts to the C-beam on the 86-91 system. I have an OEM hanger but I'll need to drill a couple of holes in the 85' C-beam to mount the hanger. so, does anyone have dimensional data on the 86-91 hole location. I could wing this, but if I have some up-front info, it would probably save me some work. TIA
Old 01-05-2015, 12:32 AM
artvette
artvette's Avatar
If you're taking about the rearmost hanger for the stock system at the main cat, there is 1 hole in the C beam. 3 1/2" down from the top and 3/4" from the edge of the "C" or reverse "C" depending on which side you're on cutout in the beam forward (a little forward of the centerline between the sections)
Quick Reply: ??? - hole location 86-91 C-beam exhaust hanger
