'92 needs a new turn signal MultiFunction Switch
So here's the symptom.... I can push the directional lever down to indicate a left turn and the turn signal will come on.... I can not pull the lever back up to turn it off ... only way to turn it off is to actually turn the steering wheel for a left turn and have it return which will turn off the turn signal. I can not turn on the right signal at all. Lever is fine but is very loose or floppy. So I believe either the MFS itself or the bracket that anchors it has cracked. Does anyone have a good write up of the procedure to remove what I need to remove to get to these parts so I can replace what I need to ??? Also, what special tools will I need ?? I have not taken this column apart before.... I assume I have to pull the steering wheel, etc .... Thanks....
GM # 26015119
There's a multitude of threads that cover replacement. A simple search here revealed many possibilities. This link may take you to some of the "search results":
https://www.corvetteforum.com/forums...rchid=45082179
If not do searches using multifunction switch, the GM part #, wiper switch replacement or similar. Find one that your comfortable with and have at it.
Here is a possible short cut.
The MFS is a pain to replace... the chassis of the switch is what fails, it is made of pig metal and has 2 long ridges on it that control the turn signal.
One of those ridges has fallen off or worn down. Take a look by removing the plastic cover behind the switch... you might be able to use something like JB Weld to fix the broken ridge and postpone the inevitable.
It's worth a shot...
Other wise, it's not a bad idea to completely rebuild the column... new bearings, new tilt springs and bushings... new switches... it's not hard, just a pain.
A link to search results will usually stick for a complete day. Create your own search. It ain't that difficult. The TS lever is secured in the wiper switch or MFS whichever you might like to call it. I even mentioned the search phrases to use.
Thanks WVZR-1.... haven't had much time to attack the problem yet and have been trying to gather as much information about the issue I am having before doing so..... I will run a search.. I did find some informative pictures on previous threads. Seems the problem I have can be the result of several different failures / breaks ....
