clearance between steering knuckle and wheel speed gear
Reassembling a C4 front suspension after blast and powder coat and finding interference between the cavity in the steering knuckle and the gear. There is powder coat inside the cavity, is it that tight ?
You've got the knuckle, the hub and the ABS sensor so I'd think you only need to acquire the proper measuring devices, learn how to use them and maybe the proper way to prep a part for powder.
If it were an issue I would have thought a more appropriate post might have been that a certain mil thickness created an issue vs. your post.
You don't mention where the interference is so it's difficult to actually respond. Is the issue depth of the knuckle bore, diameter of the knuckle bore in relationship to the reluctor ring, both or WHAT?
This is a DIY project or a "for hire" project?
Find someone with an "eddy current" mil thickness instrument if you're interested in your actual issues maybe. A professional powder coater would/should have one.
I can see where it certainly could become an issue but it certainly I would think could have been avoided by proper preparation of the knuckle before hand. Powder mil thicknesses can vary widely and are certainly much thicker than a typical "solvent" based application.
G'
