Need video tutorial on power steering pump hose removal for an 89.
Old 01-25-2015, 11:12 AM
vetdrem
vetdrem's Avatar
Default Need video tutorial on power steering pump hose removal for an 89.
I have a 1989 Corvette with the L98 engine in it. I have looked everywhere for a video showing step-by-step how to remove and replace the hoses from my power steering pump. Any help with finding a video like this or if someone could walk me through it I would really appreciate it. Thanks! Tammy {Vetdrem}
Old 01-26-2015, 11:32 AM
Doggie Dawg
Doggie Dawg's Avatar
Default Power Steering Pump
It's not hard. Just a pain in the AZZ
Old 02-16-2015, 02:11 PM
vetdrem
vetdrem's Avatar
Yes, it is. Does anybody know of a video showing how to do it?
Old 02-17-2015, 01:12 AM
Cliff Harris
Cliff Harris's Avatar
I think the possibility of finding a video like that is really small.
Projects like this are too simple to warrant a video. Remove bad/old/ugly/worn part and replace with new part.
You will need flare nut wrenches. I recollect is that the size at the top of the hose is different than the one at the bottom. Since you should have a new hose in hand you can use that to determine what wrench sizes you need.
What I found when I replaced mine is that I could not get the wrench to turn when I got it on the steering rack end of the hose (too much interference). I bent the pipe back and forth until it broke off (I didn't want to cut it with a hack saw and get metal bits inside the system). Then I used a 6 point socket to get the flare nut out
Old 02-18-2015, 04:18 PM
Joe C
Joe C's Avatar
Old 02-22-2015, 04:07 PM
yucho
Cruising
yucho's Avatar
Default Pictures
I just changed out mine using the link below for reference.
http://www.superchevy.com/how-to/040...steering-pump/
Hope this helps you.
To Need video tutorial on power steering pump hose removal for an 89.
Quick Reply: Need video tutorial on power steering pump hose removal for an 89.
