how does this valve stem wear pattern look?
Well engine has been run for total of about an hour. The wear patterns look thin but off center. What do you all think? Engine is solid roller with about .630 gross lift. Planning on spinning it to 7k, Afr 220, 1.6 Harland and sharp rr, hardened thick wall pushrods which were pretty pricey and I would rather not buy them again..
Bonus: here is the nick the piston stop made. I will just lightly sand it I guess.
....... It will be fine ... For peace of mind you can measure the half moons and the stem itself with calipers and verify that you're pattern is in the middle of the stem at some point ... preferably midway to full open ... Same with the nicks on the piston , they won't hurt anything but while you're there you might as well polish them up a bit ...........
I'd go with longer pushrods. If you're spinning the motor, it has to be right. As it is, you'll have uneven guidewear and...
can you get an adjustable push rod for setting overall length needed to center the pattern in the middle of the valve stem, and then order custom length(s) to match ?
With the solid roller, what kind of valve lash do you run?
A new set of these push rods are over $200 since the springs are so big.
I run .025 lash.
Yes they are the Afr 8000
Go with a different manufacturer if you need to. You should be able to obtain a perfect pattern with the correct length. Custom order them if you need to. Your pattern starts at the center and moves towards the outside. You don't want to run with the geometry thus far off.
Yes, witness mark toward the exhaust means the pushrod is to long, witness mark towards manifold means the pushrod is to short....When Pete Kane originally built my motor , the witness mark on the valve tip was almost half of what it is now....When I changed to the Crane Gold rockers, the witness mark opened up ( wider) to what you see above in post #9 , but at least it is centered........WW
Received 3,043 Likes
St. Jude Donor '05
Wonder if .5 less would be just about right
Manley makes a real nice pushrod, trend etc. Never bent or busted one yet.
On my original problem I had with the clearancing the large retainer lash caps were a thought and I even bought some then called Afr and they said don't do it. Get the right rocker so I did Harland and sharp.
I don't get how shimming the rocker stud would do anything...? The rocker doesn't bottom out in the first place, so it would just leave more threads up top but still have the same angle... Or maybe I'm visualizing it wrong.
Shorter push rods.... My ones I have now are 7.950 so I guess I will try a 7.900 since my measurement was in between the two.... Some of the patterns are very close to the center so if the 7.900 puts the wear pattern too close to the intake side I can mix and match depending on the valve. Some of the rockers are angled because of clearance to pushrod to the head... Afr said this was because large runner volume in the 220cc head....
7.900 are common length.
Just going off Summit prices.
.080 wall are between $100 for TFS and $130 for Manley.
.120 wall are $192.00 from Manley.
If I had to choose between the pattern being slightly towards the exhaust side or slightly towards the intake side.... as long as the roller is starting out on the intake side, rolling outwards to the centerline and back to the intake side.... you'll have more lift at the valve if its slightly towards the intake side.
Will
Will
Afr said I need to use .120 wall rods and so did comp cams (they just want more money). I'll bite the bullet and get the smaller rod.
My pattern width is much larger than any walkthrough or guide to setting a pushrod length. Is that because of my high lift? Does anyone have a smaller pattern and have close to .700 gross lift?
I'd get an adjustable pushrod, install a weaker spring, mark the valve tip, adjust it until the pattern is centered, send the pushrod out to have the right ones made.
I don't understand why anyone would put so much money in an engine build, get so close, then want to leave something "close enough".
