TPIS Headers
TPIS Headers
I just bought a set of used TPIS Headers and Y pipe (great price), for my 85.
Looking at the installation instructions on the TPIS site it mentions that it is a direct fit no alterations. But reading various posts on header installations I need to replace my starter with the smaller unit.
The question is do I need to replace or can I keep it?
Also, I could not fin an ARP part number for stock bolts for the exhaust manifold, when I replace them with the headers I want new hardware as well does anyone have a part number? I saw some at Corvette Central, would that be my best options.
I will never install headers again that are not ceramic coated. Thos, especially true with most 'new' cars that are built with so much underhood plastic.
A prime reason I went with an IMI (American made) mini-starter was to get more clearance from the exhaust due to hot start problems. It was part of, not the entire, cure.
Received 1,401 Likes
Have to? no, i didn't on the 86 and its the same starter as 85. Its just very tight, and then prone to heat soaking, even with the ceramic coating.
I do still recommend that you change to the later starter though. After I swapped i was very happy with clearance, it fired up like a snap and had zero heat soak problems.
Thanks again
You can change the wire to the 88-91's wire, which is a little longer, or splice and solder the wires to the solenoid to make them extend long enough. I didn't have to do that. I have seen where others here over the years had to shim it to make it fit perfect, but I didn't have to do that either.
I have them on my '90 which may have a smaller starter then the '85. The headers should bolt up to your exciting setup, they can and will run very close to the right side X-brace but, they will clear.
If you don't have an MA exhaust law... you could think about changing things after the Y-pipe.. maybe open things up just a bit.
I installed TPiS headers on my 85 with the stock starter. They've been on there for 6 years now with no issues. As far as bolts go, I use the stock bolts where accessories attach. I use stainless allen bolts for all the rest. As I recall they were 3/8-16 x 2". I did wrap the starter wires and other wires that were close to the headers with heat tape.
Starter
thanks
