wiring harness advice
Still trying to thin out my harness in the engine bay. I just need to keep the wiring for the alt. and front lighting all the other things will be in the aftermarket FI system. I have the factory shop manual and trying to figure out which pinouts go to what. Lotta dam wires in that harness. I have a bit of a problem nocking out the pins with the tool they come out pretty hard. Anyone have any advice on thinning this mess out. Pipe
Mention the year and it might be much easier.
Only on '89 and earlier cars. There's several threads related to sorting/separating that pass through as it's not actually a connector but a "loom" of sorts just orientating the wires..
Sorry guys its a 88 got rid of the injector connectors cold start injector and some other stuff . Stuck myself a few times with that dam tool knocking those pins out. Checking the connectors for letter and number that can be removed. Cruise control,egr valve, mass air, ac, air diverted valve, esc can all go to. Thanks for any help. Pipe
Perhaps you can be more specific as to which connector.
