Who would be interested?
As in bigger is not universally better.
The whole point of headers is improved evacuation of spent gasses; the pulsing of the prior cylinder's gasses pulling the next; optimized for a certain volume and RPM. Like virtually anything, the choice is a compromise away from the ideal, so too-large header tubes can lessen power produced, which is why the prior posters questioned as they did.
camshaft valve timing plays a part in this , But most small blocks 406 and larger should see gains with a step style header 1 7/8 to 2" .. On a power adder especially Nitrous the bigger primaries are a MUST. The small block in my car has a set that are 2" to 2.125" to 2.250" and 4" collectors. The car will be a Dog with this header running it off the bottle, but the way i'm setting my car up you Literally have to spray it to load it up on the trailer . lol
Yes most 406+ CI motors could benefit from a larger header. Especially with the heads now day that flow like they do.
I am gaging interest and will start to fabricate some of these if there is enough interest....otherwise it will be a one off ( for me) hahaha
Just call and talk with Kerry Hitt.
Advanced Composite Products (ACP)
Harrisburg, PA
717-232-2800
He bought most all the jigs and hired Jere Stahls lead fabricator of 20yrs.
I had a set of 2" primarys built just before Stahl closed his doors and they are very nice. Took a little bit of work on the inside radius of the number 5 primary tube for plug clearance but otherwise they were perfect.
This year I shortened up the primarys to 28" (from 34") and installed some slip on merge collectors. Just to kill a little TQ on the bottle.
Will
