circuit breaker (fuse)
Dose anyone know where I can get a 35 amp fuse for my rear window defogger on my 92 Corvette convertible?
I have bought 3 so far and they are all too big even the one with GM part #. I can find 30 amp that are the right size but that won't work.
Rod
Rod
An original GM # 14103366 would be a 35AMP although I believe it's mistakenly cataloged as 30 AMP in some publications. I'm quite sure it's discontinued but I'd think something to work shouldn't be that great an issue.
If the spades of a 30 AMP match I see no reason it wouldn't likely work. When you say doesn't work what do you mean? Doesn't fit?
35amp circuit breaker
Doesn't fit, too wide, prongs too big
I don't have one to measure but I'd try a LittleFuse ACB 30 to confirm fit. Either does or doesn't and post back. Do you know that you actually need a CB? If you're attempting to just troubleshoot the defogger I'd use wires with spades attached to a correct sized CB and if the defogger then works I'd maybe beg one from someone parting a car. All '85 - '92 cars should have the CB you need.
