Transmission not shifting out of 1st gear
How exactly did you adjust the cable? Could be it's not properly adjusted even after following the FSM instructions, which are pretty simple. Or so they seem.
Hey everyone
My 93 LT1, automatic doesn't shift out of first gear. Every gear works, reverse, drive, D1 and so on. Also, when I put it drive, the car jerks forward. Basically you feel the car move when I put it in drive, with my foot still on the brake. The transmission fluid in the pics only has about 100 miles on it. Any thoughts on this?
Attachment 47873858
Attachment 47873859
Attachment 47873860
Attachment 47873858
Attachment 47873859
Attachment 47873860
Are you checking the transmission fluid when the engine /trans has been warmed up and the engine running and IDLING? The dipstick measurement will not be accurate otherwise. The engine must be "ON" when checking
I wouldn't drive around to warm it up to take a picture of the color either.
They will have to drop the exhaust to change the TV cable. If it's worn or frayed that will cause the transmission to shift hard into drive. They can pull the governor and check it at the same time. Don't think that is your problem though. I think it began, the stalling, because you're over filled with transmission fluid. Probably frothing up while you were driving. Same as if you had too much oil. Froths up and doesn't lubricate. I just went through all of this with my TV cable. And before anyone goes tinkering with your car again, get a factory service manual. It is truly worth it's weight in gold.
No the point is the transmission is not shifting properly. The engine MUST be running and warmed up. He doesn't have to drive it. Start the car and let it idle for 15 minutes, and while running then check the trans fluid after putting the gear selector through all gears. The level is much more important at this point than the color. If the original poster is not adding the correct fluid or amount it can lead to problems. We are diagnosing the issue of not shifting into gear here. This is the most logical FIRST step to take in order to find direction. We do not replace parts because we 'think' something is bad. Change the governor, adjust the governor, replace the TV cable...etc. Inspect, measure, diagnose then fix what is broke. When people say 'Hey man replace this or replace that cause i read that somewhere' is way to much overload on someone who may not have much automotive repair experience. The OP needs proper direction and coaching.....my 2 cents. Take it easy- Ozz
Too much fluid is not going to make it not shift at all. Maybe after driven or run a while it might stop shifting. I could see if there was no fluid on the stick, then it might not shift.
I will bet if he posts here after it's back from the shop the problem will be the governor gear. The unfortunate part is whether or not the shop is going to want to replace a $5 part, or convince the op his trans needs a whole rebuild and not say anything about the gear.
If you follow the FSM to adjust the TV cable , you will get it right unless the TV cable is toast. The cable's run is hidden from view for a lot of its run. It is exposed to lots of engine heat and when it works the outer case is in compression. What happens is an old one gets a soft casing (or splits) and will not hold the tension of the inner cable so it goes out of adjustment when it is pulled. The safe thing to do is replace the TV cable whenever the transmission is removed/rebuilt... cheap insurance!
#33
I appreciate all the advice
If you notice, the shifter button in Park is all the way up. In Drive, it's down. Is that normal? It wasn't like that before I got the TV cable adjusted.
#35
1993 Corvette automatic transmission problem: https://youtu.be/z_MhfSUojmg
93 Vette, auto trans problem: https://youtu.be/UevXPqxMSnk
Car was good the first 10 or 12 miles. At 60, I accelerated on the gas pedal lightly. Only thing that did was increase my RPM. Like if I was in Neutral. To get to pick up speed, I had to floor it. Called the shop, they say to bring it back. Oh, and they said the governor was sticking.
