1990 Corvette HEI Distributor
Old 03-25-2015, 06:46 PM
48vette
8th Gear
48vette's Avatar
Default 1990 Corvette HEI Distributor
I have voltage to the HEI coil, but can not get any spark to the plugs. I recently replace the Ignition control module , coil, distributor cap and rotor and it did start and run for a short while. Now it will not start and there is no spark to number one plug.
Any help would be appreciated
Old 03-26-2015, 12:46 AM
Cliff Harris
Cliff Harris's Avatar
Measure the resistance of the pickup coil. It should be around 800 ohms. They are known to crack and break into pieces.
Old 03-29-2015, 07:00 PM
48vette
8th Gear
48vette's Avatar
I checked the pickup coil and it does measure 840 ohms.
Still no spark. I also checked the Ignition module and it checks out good.
Old 03-30-2015, 12:08 AM
Cliff Harris
Are you getting 12 volts to the distributor (pink wire) with the ignition on?
I would be looking at the coil. You might have a problem with the contact between the coil and the rotor.
To 1990 Corvette HEI Distributor
Quick Reply: 1990 Corvette HEI Distributor
