1995 zf transmission lubrication point trick n trips
Hi
I've noticed on my zf bell housing there's a lubrication point (a little window), since that I currently hearing a little bit of gear buzz with cold transmission, and I figure that realase bearing could be, what is the proper procedure to add a little bit of lubrication on it?
Hi
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
You may check here, but I'm not to sure that there is a way to lub (I think its also a sealed bearing) it with out removing and replacing. Anything you try and spray may get on the clutch face.
http://www.zfdoc.com/
