12 pin connector
12 pin connector
are there only, i believe 7 used pins on the connector and are a&b top 2 on right, want to try and see my codes, and where can i get a list of what the flashes mean, thanks a lot
when you jump a@b, it will flash twelve three times....1 flash then 2 flashes....three times, then it will start flashing codes ....count the flashes...4 flashes then 3 flashes three times is code 43, it will flash each code three times, when you see three more 12's, you're done....
Try these helpful links:
http://forums.corvetteforum.com/1574918379-post18.html
http://corvettephotographs.com/c4vettes/codes.htm
What they mean:
http://forums.corvetteforum.com/1576116036-post35.html
What they mean:
