1994 LT-1 code 44
Received 6,943 Likes
2015 C2 of Year Finalist
1994 LT-1 code 44
I looked that up and that is left O2 sensor lean condition. what can cause that to act up. the other week I had a code 45 which was left O2 being rich. I found that the pig tail coming from the engine harness was messed up. So I replaced the whole pig tail carefully today.
am I looking at a bad O2 sensor? the other month I had to replace a fuel pressure regulator. would that have anything to do with this.
I know that. But what would cause this. And before I repaired the pig tail I had a code 45.
Code 44- Lean exhaust indicated. Check for possible lean fuel possibilities, such as low pressure caused by faulty regulator, fuel pump or fuel lines kinked or partially collapse, vacuum leaks, clogged air filter or fuel filter.. Check wiring and connections to O2 sensor. Check ground terminals to ecm. Replace O2 sensor
Code 45- Rich exhaust indicated. Check possibilities for a rich condition, such as faulty EVAP system canister for fuel contamination, fuel in oil, leaky injectors, faulty fuel regulator or one or more leaky fuel injectors. Also check EGR system for sticky valve or faulty control circuit. Replace O2 sensor.
It only throws the code after the engine warms up.
check your fuel pressure. I had to replace a fuel pressure regulator twice. My car (92 LT1) was throwing 44 and 55 codes. Found I only had 35 PSI on the fuel rail. Replaced fuel pump, filter, and regulator. Ended up with even less PSI on the rail (28 PSI this time). Replaced the regulator again, and things seem to be working properly now.
