Headman Header Install
the only
guess I may be the only one on here that used steel stack studs instead of the long oem manifold bolts and spacers for the alternator and a/c brackets. They look way better than the other ideas that I have seen. I also used one at the alternator,, then bent a offset in a piece of flat steel and went straight to the frame behind the drivers side A arm. It looks very clean and super sturdy.. Gggg.
Hi
I have Hedmans and like them a lot! No dipple to get them to fit, I saw in the pictures above that the wires where up and over the valve covers. I ran mine down and back to clean up the engine bay. Also my O2 sensed is in the driver side collector pointed inward . Might make the switch to a heated soon, but have had no issues of it not going into closed loop. 😄
