Uneven oil flow at rocker arms
I am getting weak oil flow at 3 of my rocker arms on the drivers side.
It still flows but not as much as the others.
I removed the rocker arm and pushrod and looked at the lifter, it looked like a pool of oil right below the lifter. I'm not sure if this was because of the oil that dripped out of the push rod or if that is where the oil is going when the engine is running.
I blew through the pushrod with my mouth and it was not clogged.
When I increase the RPMs, the oil flow at the affected rocker arms increases and you can see more coming out, however it is still weak compared to the rest at the same RPM.
I have a video of what's happening here: http://youtu.be/OvKfd0FTnmY
This is on a 1985 Corvette with a flat tappet cam.
Why is this happening?
sschultz2929 (03-05-2024)
Received 3,043 Likes
St. Jude Donor '05
x2
drive it
drive it
Are those three lifters spongy if you press down on them?
Swap rocker and pushrod with a good oiling set to rule them out.
edit: I'm sure you know, but just incase DON'T swap lifters
