Intake port layout diagrams Dart 230 Pro1 head and HSR?
Anyone have a picture (or source for) of the intake port measurements for the 230 head and Holly Stealth Ram? Don't see either on Dart's nor Holly's websites, and Google is full of other stuff.
383... Had the same thing done to mine (welded the top sections using the 1206 gasket as a guide), but I may still have a leak somewhere. Did you weld the bottom, or just the top of the intake ports?
welded about a 1/4 on the top only, Trimmed the bead to clear the valve covers, then Matched it to my converted SBC 1206 heads. No leaks!!!
Same here... and i think I have good seal after carefully grinding down those welds. Not able to find a local machine shop to mill it the right way. Will find a good machine shop when I get another one cut/welded and fully ported.
Noted that Holly install torque is 25 ft/lbs..while Dart says 35..
35 is the right number...
