Radio doesn't work after battery drain
I have a 1993 40th anniversary convertible with a stock radio/CD player.
The radio does not work after re-charging the battery. Someone told me that the radio will work after a few hours of the battery being re-charged.
Is this true?
Could it be blown fuses? I haven't had the opportunity to check yet. There are 3 fuses that operate the radio/antenna. There are 2 5amp and 1 20amp fuse(s) that operate the radio/antenna.
Any thoughts.
Is this true?
Any thoughts.
Have you tried the CD player to see if it works? The radio receiver is in a separate location and powered by a separate harness.
Is there any sound/noise from the speakers if you turn the volume up? Could be a bad amp relay.
Believe it or not, when new, the Bose system was once popular with thief's! When the Bose lost power ( stolen/removed from vehicle/battery replaced) it will lock up and refuse to work. A theft deterrent.
Instructions for resetting are in the Owners Manual. Try the factory code first.
