1993 Performance Chips
I have a stock 1993 40th anniversary corvette. I wanted to know what performnace chips I can install that is proven to boost horsepower. A lot of people I talk to say don't waste your money because alot of these aftermarket chips offer little to no performance enhancements. Anyone have any experience with these and if so what product/brand would you recommend?
The off-the-shelf chips really don't do much of anything to improve performance that you can feel. There are tuners who can create a custom tune that will provide some power gains, but it is a bit involved to do (computer, software, cable, and sending files back and forth so that the tuner can create a custom chip. There is lots of good information in the C4 Scan and Tune section about custom tuning.
You didn't say what sort of power levels you are after, but I suggest you start with a good cat-back exhaust system such as those from Magnaflo, Corsa, or Borla, While they can be pricey, you can figure on something like a 15-20HP gain from them, not to mention a much better sound.
I had the hyper crap chip....made no difference....I keep in the box in my garage to remind me not to be so stupid all the time.....vader86 has a website that will tell you what works and what doesn't...really one simple rule with a L98....if it's a cheap fix, it doesn't work.....it takes money to do it right....
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
The only real gain would be to reset fan on temps and delete cags if its a ZF6.
Pro Mechanic
If you have a 1993 automatic, I would check which final drive ratio you have. If it's like lots of '93 autos (including mine) it comes with a 2.59 ratio in the rear... not a good choice for acceleration in response. If you have 2.59, unless you're a real fiend for mileage I would make this the first mod after exhaust.
If you swap to something like a 3.55 it will feel like like the car picked up 80 horsepower, not exaggerating.
If you have a 2.59, you have the D36 ratio & you may want to consider doing a whole rear-end swap with a D44 with a performance-oriented ratio. There are pages and pages and pages of the D36 vs. D44 , all I can say is do some research and make your own decision.
Pro Mechanic
