HOW do you remove the window regulator?
This car is legit pissing me off. 2 books and they're no help. amazing. they both say it comes out the top and I'm doing nothing but getting frustrating and chipping my paint. it says NOTHING NOTHING NOTHING about taking out the metal shield and that looks like the only way to do this. nor does it say anything about removing the motor and that's one of the things that is stopping it from coming out the top.
The metal shield DOES NOT have to come completely out. I have done numerous 1984-1996 corvettes AND I do not have to take this aluminum plate all the way out. YES...I disconnect it and pull it out...and that allows me to get in and get the regulator out once all needed fasteners have been removed.
By me doing it this way...it allows me to not to have to deal with the clips that hold the linkages to the latch mechanism.
AND YES...I am CAREFUL when I pull the aluminum plate back so I can get into the door.
DUB
DUB
Amazing. I just had Joe C stop over and give me a hand. There was no possible way for me to do it like that. the regulator is too wide for the door opening.
If you only need to change the motor, don't remove the regulator.
Lower the window about 1/3 of the way. Use masking tape to keep it from moving. Clamp the regulator so the the spring does not cut your fingers off when you remove the motor.
Drill right through the inside panel and drill out the rivets holding the motor. Get a new motor for about $40 at any auto parts store. Go to a hardware store and buy some "binding posts" which have very flat heads and give more clearance than the pan head screws that come with the motor. Replace the motor. Cover the holes in the inner panel with some foil or duct tape. Done.
Did this on several cars. Sorry never took pictures.
