'INFL REST' how do i get code off?
Old 08-14-2002, 06:47 PM
grat
grat's Avatar
Default 'INFL REST' how do i get code off?
The infl.rest. light is on in my 90,any way to bypass it without scan tool?
Old 08-14-2002, 07:54 PM
blk90rdstr
blk90rdstr's Avatar
Default Re: 'INFL REST' how do i get code off? (grat)
It is possible to jump the pins at the ALDL but i forget which ones . Do a search. There is alot of info on this believe it or not. You also need to fix the root cause cause i reset mine and it came right back. Its usually rust under the impact sensors but in my case it was a disconnected plug from swapping columns. Good luck with it. :smash:
Quick Reply: 'INFL REST' how do i get code off?
