Brake light/Turn signal cancellation
I have a 1996 LT1 that I've had almost 3 years. This has been going on since I bought the car. The brake lights work when the pedal is applied and the right turn signal works when turned on independently. However, when the right turn signal is on and the brakes are applied the lights on the right side cancel each other out. I've taken it to the local Chevy dealership only to be told that their mechanics aren't familiar with older cars. I've also been told it could be a grounding issue, but no one seems to know how to fix it. I'm tired of making right turns and people stopping me at the light to tell me my tail light is out. As of now, I put my turn signal on way ahead of turning and turn it off just before applying the brakes so that all my lights work. Please help. Is like to fix it soon.
Left side is OK?
How many bulbs flash on the rear when the turn lever is used? Rapid flash or an expected flash timing? Do they function when lights are on correctly? Is it the correct filament lighting?
Apply brake and do the same bulb checks. How many light? Which? Inner outer? Rapid or expected flash?
Diagnostics I wouldn't think would be an issue and I wouldn't think time consuming.
What do you hear from the turn signal flasher when in the car? With out brake applied and with the brake applied?
People stop me and tell me my lights are not working on the right back. Yes, the lights inside don't flash, but they also don't work on the outside. I would like to know how to fix the issue if someone could walk me through it
1. Headlamps on you have how many rear lamps?
2. Left turn how many lamps flash? How bright?
3. Right turn how many lamps flash? How bright?
4. Stop lights only "no turn" how many? How bright?
5. Do the dash directional work at all?
6. What happens when the HAZARDS are activated?
7. Do the fronts work all of the time correctly?
8. When you are driving does the turn lever return to "neutral" after the completion of the turn both ways?
9. Is this a stock steering wheel with "Air Bag"?
Where do you live that you can do 3 years without a "safety inspection"? Maryland maybe?
Need to know exactly what does what or doesn't do what. I explained how to start I thought. I'd think to make it easy do these with "key on", someone else in driver seat you checking lamps.
2. Left turn signal on, 2 left lamps flash full brightness. Center lamp does not.
3. Right turn signal on, 2 Right lamps flash, center lamp DOES flash. Full brightness.
4. Brake lights, two left, two right, one center all work full brightness without turn signal.
5. Dash directionals all work.
6. Hazards all flash full brightness, front, back and dash.
7. Front lights and signals work full brightness without brake applied.
8. When driving, the turn signal lever DOES return to neutral when turn has been completed.
9. Airbag equiped both steering wheel and passenger.
when right turn signal is on and brake is applied, the lights remain illuminated but stop flashing.
I live in South Carolina and they don't require emissions or safety checks here.
---------------------- NEW ----------------------------------------
***With the HAZARDS ON step on the brake and see if the HAZARDS continue and the CENTER still works with the brake pedal applied.
Dave posted a wiring diagram and I looked at similar but was waiting for you to post back regarding the HAZARDS. Yours would be very easy to trouble shoot I believe not requiring difficult diagnostics. You'll need to remove the hush panel under the dash left side, the impact bar to gain access to the directional harness. You confirm there are no issues there first. Since your issue is stop/turn you could plug in a directional switch hanging loose from the connector and if you've got stop lights the problem is the switch which I suspected anyway.
To replace the switch you'll need to go into the column and if you're not comfortable doing that you could have a shop do it. The tools required are generally "loaners" at the local AZ or whichever.
I have a switch you could use for diagnostics, buy it if you wanted if that's your problem. You can shop new using GM# 1995974 ACD D-9001 - from me $25 and postage. Pay postage both ways to borrow for diagnostics if you like. Use the email link or PM me if you're interested.
You would unplug switch midway down column, connect one to test. You can see the connector hanging in this image:
Dave posted an image of the switch but if you GOOGLE the numbers I supplied you'll find much better.
