About to ready to call it quits: $&@! Clutch bogging engine idle
Well I didn't think it was possible but I got another problem with my recent new stroker ZF six speed combo. Engine runs just fine but the clutch when pushed in some bogs down the engine at idle. If I push it in all the way the engine drops down to 400 rpm and tries to die if I don't let off it. Didn't dare try a gear with this problem. Caged roller bearing in crank, new clutch slave and master with brand new SPEC stage 3+ clutch kit. Almost ready to throw in the towel on all this. One thing after another...
This is reaching but Ive seen this with a bad ground harness that attaches to the motor. Pushing the clutch in caused the motor to bog or die completely. Again its a longshot but has happened before.
True, but hey, here's to increasing your post count on the forum.
Trans in car when I installed engine with clutch and bellhousing bolted on. Everything came together great. Bellhousing fully seated. Car starts with clutch pedal fully depressed but pressing it in while idling in neutral is almost like a kill switch if I try to press clutch pedal in again. Manual transmission indicated in the chip programming. Burned out on this car....
Okay this is reaching, but I received the clutch pedal assembly with an attached clutch neutral safety switch, which had cut wires but left about four inches off each one. Both wires are black, as are both wires from a donor dash harness I received to connect to the switch's plug. I installed quick disconnect male/female plugs on the wires just in case I had to switch them around if I didn't "wire" it back up correctly.
I always looked at the switch as it didn't matter which wire coming out of the switch went to which wire on the dash harness because it was closing a circuit to allow voltage to the starter but if I have the wires crossed, is it possible me pressing in the clutch with crossed wires on the neutral safety switch is creating a draw/drag on the electrical to bog down the motor? I know it's reaching but the thought crossed my mind. The gauge of wire on the neutral safety switch wiring is decent sized.
Post count is not important to me.... I erased about 2000 about 10 years ago in protest to posters getting the same count for posting an icon, compared to posters helping with a multi-paragraph solution.
throw-out bearing? Im just trying to think mechanically what would cause this. To prove your theory on electrical drain you could watch the voltage gauge on dash when depressing the clutch. Do you have a scan tool. Im guessing as well but with keys in run position and engine off I would press and release the clutch while watching the scan tool for any relays/solenoids/or whatever changing state. Maybe your clutch input is going to wrong input on computer. In return the computer is trying to compensate with fuel air mixture.
Received 3,043 Likes
St. Jude Donor '05
Youll never start the car in gear, bypass the switch
Does the car want to slip in gear Ok other than the rpm thing?
Dont give up on the car your way down the homestretch! I understand though after fooling with one taken apart for 10 yrs.
Hoping all is well so you dont have to pull your trans back out (I had to twice in the first 50 mi if that makes you feel any better)
Edit: have someone depress the clutch then watch the balancer see if it moves forward
Does it grind at all when trying to engage gears at an idle? Can you try an bypass the clutch relay? Man, don't give up. What happens when you try to start the car with it in gear but clutch pressed in?
Little head scratcher but it's a bit of good news after yesterday. I talk a big game but I've cooled of since yesterday. You just hate to spend money like this on new parts for years and have to fight it every other step. Preaching to the choir. That's hotrodding.
St. Jude Donor '05
Did you do a ZF conversion?
May wanna give ZFDoc a call tell him what parts you used bet he could tell you in a minute whats going on.
I have never had one of these transmissions removed from car nor am I an expert or even a novice but I do remember changing a clutch in a car several years ago with a buddy. I remember something about installing the disk the correct way. Is there springs on the clutch disk? Could you have installed this backwards?
The clutch slave is a cast iron piece I actually found based off a recommendation from LD85 in one of his old posts. Maybe the pushrod or component as a whole is over extending.
Does anyone have a diagram of what he is talking about? Let me get this straight. The clutch disk had labels or markings on it to install "this side towards trams" and it wouldn't work so you disregarded this and flipped it over?
The flywheel is an aftermarket steel one piece unit with a deep dish recess in the center. It's the exact size for the raised sprung hub to rest inside. However, the raise sprung hub side had a "trans side" sticker on it, while the flat side had "Flywheel side". It didn't seem right but I attempted this way first and the pressure plate mating surface was a good 1-1/2'' away from the flywheel with me pressing firmly on it. Flipping the disc over so the raised sprung hub went inside the recess of the flywheel allowed the pressure plate to properly mate to the flywheel to be bolted up. I did a google search on the issue and apparently there have been a few clutch discs sent out with the stickers labeling which side went which way swapped. Email sent and voicemail left for ZF Doc. Guess we'll see what he has to say.
Oh. Ok. Not picking on you or anything like that. I have a zf as well and one day will be changing clutch. Im just trying to understand and help you as well. Maybe someone will post a diagram (at least for my understanding).
So with the trans in neutral, no foot on clutch it idles fine, but when you push in the clutch with your foot the ides drops and it wants to die?
could you post some more info and pictures of what you used for the clutch and flywheel?
https://www.corvetteforum.com/forums...t-another.html
If you check that thread and scroll down to Armysnipe's pictures he posted, same setup I have, except mine is a blue pressue plate.
Sounds to me like the throughout bearing is bottoming out against something and putting pressure against the crankshaft which is putting pressure on the thrust bearing and bogging the engine down. I would study the clutch, throughout bearing, pressure plate, and flywheel that you used and make sure they are installed correctly and that they are the correct parts.
The flywheel has a deep dish recess in it that looks made for the hub, so when I flipped it over it went together perfect and the pressure plate actually would mate to the flywheel to bolt together. I even have ZF Doc a little puzzled on this one. He suggested I have a helper press the pedal in while I watch the flywheel from underneath for any shift in movement noticeable by eyeballing it.
I'm praying I don't see it when I try it but we'll see. Clutch pedal feels great, I never feel any "feedback" or weird vibrations through it when pressing down. Third time is the charm for checking it this weekend guess.....
