exaust manifold fitting
the air fitting on the center of my exhaust manifolds have got to go with the air pump and egr assemblys. I already have them programed out (92lt1) Does anyone know the size of that fitting so I can find a plug. Is it pipe thread or standard bolt thread and what size?? I know I could cut the pipe off and weld it shut but id like to keep the assembly complete in case Michigan gets a case of the CA smog police Thanks a bunch.
If they're 7/8-18 thread then I believe I'd buy 5/8 INV FLARE plugs to do the job correctly. Those should seal correctly and if I'm correct you should be able to look at what you've removed and see that it resembles an INV FLARE. You should also I'd think be able to look into the manifold and see the sealing surface. The INV FLARE does the correct sealing so if you wanted to go back you wouldn't have to deal with deterioration of the threaded bore.
If you needed to shop these locally they could be referred to a -10 if you were shopping a Parker vendor.
** I checked with a jobber that I'd customarily buy from and I don't see the offering. Is there? Maybe.
came to see you sunday.. you were in church....since it's back to the 30's again, I'll be by when it warms up....my florida vette doesn't like cold, ( or rain/snow)....is it really may ????? My wife is NOT a yooper and not pleased...!!!!
stepson said you stopped by. Heck pal your throwing away a big part of summer around here. If theres no snow its beautiful out. Vettes still torn apart but your sure welcome to stop over for a beer or a visit. I around most days. If im not home listen for shooting and if you here so go over to the old Yamaha shop and take the road back to the sand pit.
